Feeler HV, VB and VMP Series
Methods Machine Tools Inc. has introduced FEELER Vertical Machining Centers featuring extensive engineering by Methods, designed to provide users performance and value.
July 1, 2010
Methods Machine Tools Inc. has introduced FEELER Vertical Machining Centers featuring extensive engineering by Methods, designed to provide users performance and value. The FEELER VMC line is backed by Methods' application expertise, support, and extensive network of technology centers. The line includes the HV-Series, VB-Series and VMP-Series. The FEELER HV-Series VMCs, including HV-800 and HV-1000 models, offer high-performance machining featuring 1G X-Axis acceleration and 1.9 second tool change time in 800mm or 1,000mm X-axis travels. Roller guideways are on the X and Y-Axes. A 15,000 rpm, 30 HP direct drive, 40 taper spindle, FANUC 18i-MB Control with 4th Axis prep. and 30-tool automatic tool changer are standard. The FEELER VB-Series VMCs are heavy duty boxway machines featuring a high torque two stage gearbox and spindles from 15 HP to 30 HP, available in 40 or 50 taper. Models include VB-900, VB-1100, VB-1300, VB-1400, VB-1650, VB-1900 and VB-2200. X-Axis travels range from 900mm — 2,200mm (35" — 87"), Y-Axis travels range from 610mm to 1,000mm (24" — 39") and Z-Axis travels arefrom 600mm to 800mm (24" to 31.5"). A 30-tool automatic tool changer and FANUC 0i-MD control are standard. The FEELER VMP-Series includes the VMP-580, VMP-800 and VMP-1100 models with 10,000 rpm spindles ranging from 15 HP to 25 HP. The VMP-580 machine is also available in an APC pallet changer version. Machines feature linear guideways on X and Y-Axes and boxways on the Z-Axis. X-Axis travels range from 580mm to 1,100mm (23" — 43"), Y-Axis travels range from 420mm to 610mm (16.5" — 24") and Z-Axis travels are from 510mm to 600mm (20" — 23.6"). The VMP-580 features a 24-tool automatic tool changer and the VMP-800 and VMP-1100 use a 30-tool automatic tool changer. A FANUC 0i-MD control is standard on the VMP-Series machines. The rigid FEELER VMCs range in weight from 6,600 lbs. (3,000 kg) to 48,400 lbs. (22,000 kg) and include a two year warranty. The full range of FEELER machines encompasses Vertical Machining Centers, Turning Centers, Bridge Mills and Boring Mills. FEELER machines are manufactured by Fair Friend Group (FFG).
