ISO-EcoTurn Inserts
ISO-EcoTurn Inserts
ISO-EcoTurn inserts, while downsized for tool economy, incorporate the identical chipbreaker geometry and thickness of regular sized inserts to maintain the same cutting performance at a depth of cut up to 3.0 mm (0.12"). This expansion provides more cost efficient solutions in steel turning applications.
June 16, 2021
Tungaloy has expanded its ISO-EcoTurn cost efficient turning insert line by adding 63 inserts in new geometries.
Major expansions have been made to existing NS9530 uncoated cermet insert, GT9530 and AT9530 coated cermet insert, and T9215 and T9225 CVD-coated carbide insert lines by increasing nose radii and chipbreaker style options.
TS style chipbreaker, which is a chipbreaker for finishing process proven for superior chip control at light cutting depths, is now available on cermet inserts, providing extended tool life and wear predictability for finish turning of steel parts.
Existing ZF and ZM style chipbreaker lines have also been expanded, increasing geometric options that provide better chip control in challenging finish profiling of intricate 3D surfaces. Along with new nose radii options, an expanded insert family of ISO-EcoTurn will further deliver cost efficient, high-performing turning solutions to customers.
  • depth of cut
  • chipbreaker
