Klüberplus Z 01-006 US Water-Based Solvent
Klüber Lubrication introduces Klüberplus Z 01-006 US, a water-based solvent containing wetting agents, corrosion inhibitors and degreasing compounds.
Klüberplus Z 01-006 US can be used to safely remove lime deposits or water scale in commercial and industrial applications, such as:
- Power plant boilers, piping systems and evaporating equipment
- Equipment in refineries, utility companies, paper mills, chemical plants and foundries
- Sewage disposal plants, water treating facilities and other municipal water handling operations
This solution is noncorrosive, so it will not adversely affect stainless steel, carbon steel, brass, admiralty metal, copper, iron, lead, PVC plastic, polyethylene, rubber, leather or most metals and/or materials normally found in water-wetted equipment. Additionally, it is nontoxic and nonflammable.
