KPC-Series Polygon Taper Shank Holders
Kyocera Precision Tools introduces the new line of polygon taper shank holders for high-rigidity and high-precision machining.
The special polygon taper design with dual contact between the taper and the flange face along with an even distribution between 3 faces on the sides of the flange create a rigid body with locational accuracy within +/-2um. The KPC-series features several holder styles for turning, grooving, cut-off and threading applications.
