Lubricut 5000 Metalworking Fluid
Lubricut 5000 from Chemtool Inc. is a uniquely formulated metalworking fluid based upon synthetic technologies for utilization as a mist or near dry machining lubricant for all metals. Lubricut 5000 is non-water-miscible.
Lubricut 5000 is particularly well-suited for cut-off operations where fluid misting/ near dry lubricants are utilized. The lubrication properties of Lubricut 5000 allows for extended tool and cut-off blade life while depositing only a minimal residual film, according to the company.
Lubricut 5000 is particularly effective as a saw lube for aluminum billets and extrusions for both cast and regular aluminum alloys as well as most non-ferrous metals. Lubricut 5000 exhibits low-mist properties and a low V.O.C. value of only 4.7 grams/liter making it a highly compatible product for environmental compliance and extremely safe working conditions.
Product benefits include:
Outstanding lubrication based upon blend of synthetic esters and high molecular weight polymers
Contains no chlorine, phosphorus, boron nor zinc
Contains balanced nonferrous corrosion inhibitor
Low odor and transparent appearance for worker acceptance
Low viscosity ideal for misting/near dry applications
High flash point and low-mist/smoking characteristics
Low V.O.C. value of only 4.7 grams/liter
Effective selection for the machining of both general and automotive alloys, both ferrous and nonferrous
Copper corrosion rating of 1b via ASTM D130
High oxidative stability
High viscosity index
Excellent micro-tap lubrication results on both ferrous and non-ferrous metals with form taps
  • alloys
    alloys
  • aluminum alloys
    aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
  • flash
    flash
    Thin web or film of metal on a casting that occurs at die partings and around air vents and movable cores. This excess metal is due to necessary working and operating clearances in a die. Flash also is the excess material squeezed out of the cavity as a compression mold closes or as pressure is applied to the cavity.
  • metalworking
    metalworking
  • sawing machine ( saw)
