Dormer Pramet launches new Pramet chipbreakers and grades. The NF1 and NF2 positive chipbreakers support turning applications in stainless steel while the FF2, FM2 and RM3 chipbreakers support steel and cast iron. The SF2 and SF3 positive inserts are first choice for S-group materials and high-performance alloys.
The NF1 is a universal chipbreaker for fine finishing to medium machining, peripherally ground to impart a fine surface finish. The versatile NF2 chipbreaker incorporates a small stabilizing T-Land and covers a range of applications from semifinishing to light roughing.
The FF2 chipbreaker has a positive rake angle and depth of cut from 0.01 inch for fine finishing applications in low carbon steels. The FM2 chipbreaker is for finishing to medium machining and features a protective land suitable for continuous and interrupted operations. The highly resistant RM3 chipbreaker is for roughing applications in steels and cast irons and suitable for unfavorable machining conditions.
The SF2 and SF3 positive inserts provide a highly secure and dependable option for turning applications for S-group materials and high-performance alloys. The SF2 chipbreaker is for fine turning at the lowest possible feeds while the SF3 chipbreaker, with its positive inclined cutting edge, supports finishing operations. Especially effective when used on small and slender components, both inserts offer a sharp cutting edge with minimal radius. This promotes low cutting forces which, in turn, prevents work hardening and ensures a high quality surface finish.
Finishing off this new Pramet offering is the T7325 grade for productive machining of stainless steels. It has been developed to complement the existing T7335 grade, which is recommended for use in unstable machining environments. Suitable for interrupted cutting, the latest T7325 grade features a functional gradient substrate and special MT-CVD coating. This combination offers high cutting strength, reduced built-up edge and resistance to the formation of cracks. As a result, the grade provides a high level of operational reliability, performance and tool life.
- alloys
alloys
- built-up edge ( BUE)
- carbon steels
carbon steels
Known as unalloyed steels and plain carbon steels. Contains, in addition to iron and carbon, manganese, phosphorus and sulfur. Characterized as low carbon, medium carbon, high carbon and free machining.
- cast irons
cast irons
Cast ferrous alloys containing carbon in excess of solubility in austenite that exists in the alloy at the eutectic temperature. Cast irons include gray cast iron, white cast iron, malleable cast iron and ductile, or nodular, cast iron. The word “cast” is often left out.
- chipbreaker
chipbreaker
Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
- depth of cut
depth of cut
- hardening
hardening
Process of increasing the surface hardness of a part. It is accomplished by heating a piece of steel to a temperature within or above its critical range and then cooling (or quenching) it rapidly. In any heat-treatment operation, the rate of heating is important. Heat flows from the exterior to the interior of steel at a definite rate. If the steel is heated too quickly, the outside becomes hotter than the inside and the desired uniform structure cannot be obtained. If a piece is irregular in shape, a slow heating rate is essential to prevent warping and cracking. The heavier the section, the longer the heating time must be to achieve uniform results. Even after the correct temperature has been reached, the piece should be held at the temperature for a sufficient period of time to permit its thickest section to attain a uniform temperature. See workhardening.
- land
land
Part of the tool body that remains after the flutes are cut.
- rake
rake
- stainless steels
stainless steels
- turning
