NuSol Lubriform Superior
NuSol Lubriform Superior is a new forming technology that Chemtool Inc. has introduced to the metal forming industry for the forming of ferrous metals and exotic alloys.
NuSol Lubriform Superior is a new forming technology that Chemtool Inc. has introduced to the metal forming industry for the forming of ferrous metals and exotic alloys. NuSol Lubriform Superior is formulated for today's competitive forming environment which demands one forming fluid for all operations.
NuSol Lubriform Superior is manufactured using a proprietary blending process that incorporates into the product many unique characteristics that will promote high productivity rates and minimal downtime for the end user, according to the company. It is formulated using a blend of unique preformed emulsions that possess a very small particle size (average particle size of 1µm) which demonstrate outstanding boundary lubrication. This small particle size provides a very durable and uniform lubricant film, enhanced wetting and coverage, a clean running fluid, and exceptional hard water stability for enhanced forming performance on ferrous alloys.
NuSol Lubriform Superior preformed emulsions are further complemented with the presence of boundary lubrication agents which offer enhanced wetting, film strength and balanced lubrication. NuSol Lubriform Superior also contains low levels of chlorine and sulfur (non-active) for demanding forming operations. NuSol Lubriform Superior can also be used as a metalworking fluid for facilities looking to consolidate forming and machining fluids to one choice, NuSol Lubriform Superior.
NuSol Lubriform Superior FEATURED BENEFITS:
Excellent corrosion protection for all tooling, equipment, and parts
Exceptional lubricant film strength for good tool life and finish on all metals
Extremely small particle size for superior wetting and coverage on all metals
Excellent hard water stability
High degree of cleanliness and low reportable VOCs (only 21.1 g/l) for operator acceptance
Fortified with chlorine and sulfur for demanding lubrication operations
Excellent rejection of process oils and system contaminants
Dual use capabilities for both forming and for utilization as a synthetic machining fluid for ferrous applications.
