Oil Shear Crane Motor Brakes Brochure
Elimination of the wear significantly increases service life and virtually eliminates adjustment and maintenance. These totally enclosed brakes are impervious to the dirt that are common in manufacturing environments. In addition to cranes, Force Control oil shear motor brakes are ideal for applications where the motor is reversed each cycle such as elevators for green or cured concrete products, conveyors, loaders/unloaders, stackers, and more.
Oil Shear crane motor brakes from Force Control Industries are detailed in a new 4-page, full color brochure. These proven products provide longer service life with no maintenance or adjustment required, even in demanding applications.
Elimination of maintenance and adjustment, which is done at height, enhances safety. Proven oil shear technology transmits torque between lubricated surfaces – thereby eliminating wear on friction surfaces. A patented fluid recirculation system dissipates heat – eliminating heat build-up which is the most common problem in dry braking systems.
Elimination of the wear significantly increases service life and virtually eliminates adjustment and maintenance. These totally enclosed brakes are impervious to the dirt that are common in manufacturing environments. In addition to cranes, Force Control oil shear motor brakes are ideal for applications where the motor is reversed each cycle such as elevators for green or cured concrete products, conveyors, loaders/unloaders, stackers, and more. The new brochure includes is available online at https://bit.ly/3w8Hw7a.
All Force Control products are made in the USA with industry leading lead times. By eliminating maintenance and adjustment, they are an ideal replacement for dry braking systems made by Stearns, Nexen, Warner, Dings, and others.
