PUMA V8300 Vertical Turning Center
Doosan Machine Tools presents the new PUMA V8300 vertical turning center with an toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: automatic toolchanger">automatic toolchanger (ATC). The PUMA V8300 is a new generation 15-inch class vertical turning center with a large work zone and enhanced rigidity and user convenience. It is available in right- or left-hand versions.
The PUMA V8300 offers a maximum turning diameter of 830mm (32.7"), a maximum work height of 750mm (30") and a swing-over-saddle of 740mm (29").
The adoption of a standard 37kW (50hp) high-power spindle motor and a column integral-type box guide structure ensures heavy-duty, stable, dependable turning performance. The high-reliability, servo-driven turret maintains high accuracy during long-term machining. The PUMA V8300 has a maximum spindle speed of 2,000 rpm and maximum torque of 2,592 Nm (1,912 ft-lbs).
The PUMA V8300 comes with an optional 12-station ATC magazine, a feature not usually found on turning centers in this class, according to the company. The ATC supports Capto C6 tooling and is available for all 12 stations of the turret. The tools remain safely out of the way when not in use, providing superior tool management and much easier maintenance.
The PUMA V8300 series is designed with a slanted bed and an improved flushing function for unhindered chip disposal, and expanded coolant system features a 290 liter (77 gallon) tank. It also has an ergonomically designed operation panel that swivels and is height-adjustable and movable for enhanced user convenience.
"We set out to design a new vertical turning center with the features and benefits our aerospace, automotive and energy customers were asking for," states Jim Shiner, director of sales and marketing at Doosan Machine Tools America. "These characteristics make the PUMA V8300 particularly well-suited for any operation with the need to cut tough materials swiftly and efficiently."
