Silver-tec Silver Turning Inserts
Walter USA LLC has introduced the new Tiger̢蠉ã¢tec Silver Turning for steel turning applications. Consisting of three new grades and four new geometries, this product line can bring longer tool life, faster cycle times and process reliability to a wide array of applications. The Tiger̢蠉ã¢tec Silver Turning can handle a variety of materials including unalloyed and alloy steel, cast steel, stainless ferritic and martensitic steel, as well as ductile cast iron.
Key to this success is the proven Tiger-tec Silver CVD coating. When combined with the newly developed insert geometries and universal chipbreakers, it can increase steel turning productivity up to 75 percent. The substrate for these indexable inserts is a new, micro-structured aluminium oxide. Thanks to its specially oriented crystalline structure, it can also raise tool life in the event of crater wear by 50 percent, which significantly reduces machining time.
In addition, an optimized cutting edge preparation process called Microedge Technology reduces cracks, micro-chipping and breakage, boosting process reliability in high volume production. Microedge Technology can also increase tool life by 30 percent by reducing flank face wear and plastic deformation of the insert. Process reliability is heightened when making interrupted cuts as well, thanks to optimum seating of the new inserts in the toolholder. The inserts&' silver flank faces also serve as an indicator layer for easy wear detection.
The new generation of indexable inserts for steel turning consists of three grades: WPP10S (ISO P10), WPP20S (ISO P20) and WPP30S (ISO P30). The WPP10S grade (ISO P10) offers the highest temperature resistance and hardness and provides excellent wear resistance and is suitable for applications ranging from continuous cutting up to slightly interrupted cuts. The WPP20S (ISO P20) is a universal grade for applications ranging from roughing to finishing. The WPP30S (ISO P30) grade was developed for tough cutting conditions.
Alongside these three grades, four previously introduced geometries have been developed in parallel within the Tiger̢蠉ã¢tec Silver Turning family: FP5, MP3, MP5 and RP5.
  • chemical vapor deposition ( CVD)
  • edge preparation
    edge preparation
    Conditioning of the cutting edge, such as a honing or chamfering, to make it stronger and less susceptible to chipping. A chamfer is a bevel on the tool’s cutting edge; the angle is measured from the cutting face downward and generally varies from 25° to 45°. Honing is the process of rounding or blunting the cutting edge with abrasives, either manually or mechanically.
  • hardness
    hardness
  • parallel
    parallel
  • plastic deformation
    plastic deformation
    Permanent (inelastic) distortion of metals under applied stresses that strain the material beyond its elastic limit.
  • toolholder
    toolholder
  • turning
  • wear resistance
    wear resistance
