TechniDrill TBTA-10-180
The TBTA-10-180 is a single spindle machine with 10 inches (254 mm) of trepanning diameter capacity and 180 inches (4,572 mm) of trepanning depth. It has the capability for both a rotating tool and a counter-rotating workpiece, both of which are driven by 100 HP motors.
July 14, 2022
The TechniDrill TBTA-10-180 is a deep-hole drilling machine using the BTA process (Boring & Trepanning Association). It can drill holes up to 10 inches in diameter from solid using the trepanning process. The machine has applications is both the aerospace and oil & gas industries.
The trepanning process doesn't drill the entire diameter of the hole, only a ring of material on the periphery. Instead of turning all the removed material into chips, a core is left in the center of the hole. This enables the machine to drill larger diameter holes with less required horsepower.
  • trepanning
    Drilling deep holes that are too large to be drilled by high-pressure coolant drills or gundrills. Trepanning generates a solid core and normally requires a big, powerful machine…
