A portable pipe beveling tool for preparing torched-off or rough cut pipe ends and making them square to help create high-integrity welded pipe joints is available from Esco Tool. The Terminator MILLHOG pipe beveling tool attaches to the ID and features a tracker which compensates for variations in the pipe’s wall thickness to maintain a precision bevel and has a dual-spring safety hanger to simplify the alignment of larger pipe. Suitable for pipeline construction, it can produce any angle of bevel, face and counterbore simultaneously.
Designed for prepping pipe from 8-5/8” ID up to 36” OD, the pipe beveling tool and has an adjustable toolholder that indexes and locks for easy setup. Equipped with user-selectable formed TiN-coated tool bits, it comes with a 5-hp pneumatic motor or an optional hydraulic motor and produces a thick chip without requiring cutting fluids.
- counterbore
counterbore
Tool, guided by a pilot, that expands a hole to a certain depth.
- inner diameter ( ID)
- outer diameter ( OD)
- toolholder
toolholder
