USC-2M and USC-3M
USC-2M and USC-3M
Both models feature rigid, robust frames along with their universal spindles for the toughest applications, all of which helps mold makers minimize machining time and maximize throughput. Mold makers require world-class milling capabilities and accuracy, which is why the new USC designs emphasize rigidity and stability. With CAT 50 spindles up to 40 horsepower, these machines deliver high-torque milling capabilities for aggressive metal removal and shorter cycle times.
April 23, 2020
To help mold makers achieve the highest levels of milling and deep hole drilling productivity, UNISIG introduces two new models to its successful USC-M series – the USC-2M and USC-3M. The new 2M/3M machines handle the rigors of both milling and gundrilling metals of all types, but do so with a single, powerful universal spindle. Both models feature rigid, robust frames along with their universal spindles for the toughest applications, all of which helps mold makers minimize machining time and maximize throughput.
"We believe mold makers will truly benefit from the machining capabilities of these two new models," said Anthony Fettig, CEO of UNISIG. "By introducing a pair of universal spindle options, we now offer manufacturers of all sizes a complete line of mold making solutions. The new machines exemplify a continuation of our commitment to meeting customer needs without compromising on quality or accuracy".
Thanks to the single, universal spindle designs of the USC-2M and 3M, mold makers will significantly reduce changeover times when switching between gundrilling and milling operations. Additionally, a 60-position automatic tool changer helps further minimize nonproductive time. Both models have the capability to run oil and water- soluble coolant as well. For further time and cost savings, the USC-2M and 3M feature fully enclosed machining envelopes that are installed above the shop floor, allowing customers to avoid time-consuming, costly below-ground installations.
  • gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
