V920EX One-Saddle, Vertical Lathe
Okuma's new V920EX one-saddle, vertical lathe features a powerful turning spindle and a large work envelope, making it ideal for cutting a variety of large, heavy parts. The V920EX boasts a work envelope with a maximum turning diameter of 36.22" and 33.86" of swing over the saddle enabling it to accommodate large, odd–shaped workpieces.
Okuma's new V920EX one-saddle, vertical lathe features a powerful turning spindle and a large work envelope, making it ideal for cutting a variety of large, heavy parts. The V920EX boasts a work envelope with a maximum turning diameter of 36.22" and 33.86" of swing over the saddle enabling it to accommodate large, odd–shaped workpieces. Highly rigid construction and powerful ballscrews generate slideway movement to both axes for precise machining of heavy parts, according to the company.
Maximum machining productivity is achieved with a V12 turret and foolproof chip discharge. Designed for smooth chip flow, optional side or rear chip conveyors can be placed to match discharge direction based on shop floor requirements. Maintenance tasks are simplified with easy access to the air filter, hydraulic unit and coolant tank on the back of the machine.
Okuma's Thermo-Friendly Concept is standard and automatically compensates ambient temperature changes to maintain tight tolerances. Cycle times, lead times, and energy costs are significantly improved with Okuma's open architecture OSP-P300L control and ECO suite feature.
Key features of Okuma's V920EX vertical lathe:
Max Turning Diameter in Ø 36.22/33.86
Max Swing in Ø 39.37
Max Cutting Length in 33.86
Turret Type V12
RPM Range 20 to 1,250
Floor Space (in) 88.646 x 112.01
Weight (lb) 25,133
