VA-L 500 Circular Cold Saw
Behringer Saws Inc. has added the VA-L 500 to its line of circular cold saws. Behringer Eisele GmbH designed the VA-L 500 sawing system specifically for production cutting of aluminum and nonferrous materials.
October 31, 2016
Behringer Saws Inc. has added the VA-L 500 to its line of circular cold saws. Behringer Eisele GmbH designed the VA-L 500 sawing system specifically for production cutting of aluminum and nonferrous materials. With a frequency-controlled main drive system and adjustable cutting speeds, the VA-L 500 can saw the full range of aluminum alloys and other nonferrous materials in solids, thin-walled pipe and profiles highly efficiently.
The VA-L 500 saw comes standard with a 32 H.P. frequency-controlled drive motor with 800-3,400 rpm speed range and a servo-driven downfeed with an adjustable rate from .39"/sec to 19.6"/sec, to ensure the fastest possible cut times. The fully automatic high-performance circular cold saw has a cutting range of 6.0" (152 mm) for round materials or 6" x 6" (152x152 mm) for square materials at 90° using a carbide-tipped circular saw blade with a diameter of 19.6" (500 mm). With a robust overall design with the latest drive technology in the feed axis and stiff saw blade guiding, the VA-L 500 reportedly ensures optimal, low-vibration sawing with excellent cutting performance and surface finish quality.
"Our VA-L series features a heavy-duty design, state-of-the-art drive technology used in the feed axis and main drive system, and an extremely rigid, ultra-precise saw spindle bearing," commented Joe Suydam, inside sales and marketing manager at Behringer Saws. "The result is an optimized, low-vibration cutting process that provides maximum cutting output and excellent surface finish quality in both solid materials as well as in pipe and profiles with sophisticated cross-sectional geometry."
An automatic blade/material separation feature guarantees a free return of the saw blade, reducing blade damage and resulting in high quality material finishes. An NC gripper feed unit, driven by a servomotor, ball screw spindle and encoder with a single stroke capacity of 39.3", ensures quick and precise movement of material.
A Lift-and-shift device for material feed, a standard feature of the VA-L 500 saw, ensures the material is lifted slightly over the material support table, enabling the material to be "freely" fed without touching the material table and clamping jaws, eliminating damage to the surface of the material. Furthermore, to reduce buildup of chips and scratching of material, a blowing device rapidly removes chips from the clamping area, providing a clean material clamping surface area and unobstructed material flow for increased service life. Also standard on the VA-L 500 is a material disposal/discharge unit featuring a support plate and a sorting chute that moves trim/remnants and parts into two separate areas.
  • aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wro…
  • circular saw
    Cutoff machine utilizing a circular blade with serrated teeth. See saw, sawing machine.
