2-Inch Transparent Receiver Laser Alignment Accessory
Pinpoint Laser Systems announces the release of its latest laser alignment accessory, the 2-Inch Transparent Receiver, for receiving laser signals to achieve machinery and equipment alignment.
June 7, 2018
The 2-Inch Transparent Receiver differs from Pinpoint's existing Transparent Receiver in that it is significantly larger than the original. While the original receiver window measures ¾"x¾", the 2-Inch Transparent Receiver window measures 2"x2", allowing for a wider range of measurements down to 0.0001 inch and over distances of 150 feet or more. As with the original Transparent Receiver, it is also manufactured with solid aluminum housing and reference surfaces and mounting points for a number of industrial applications.
Pinpoint's 2-Inch Transparent Receiver works by allowing the incoming laser reference beam to pass cleanly through to other receivers while making a precise pair of linear measurements. The position of this receiver is measured in real time to the centerline of the laser beam for precise measurements of machine tool motion and other industrial applications.
The 2-Inch Transparent Receiver is Pinpoint's latest innovation for engineers and machine operators to achieve lathe and spindle alignment, machine tool runout, roll and web alignment, precision bore alignment, among other industrial applications. This product is available as is or can be customized to meet a manufacturer's exact specifications if needed.
