Tech-Cool 35052
Tech-Cool 35052 from Chemetall is a semisynthetic metalworking fluid for machining cast and wrought aluminum alloys, stainless steels, titanium and nickel-base alloys. According to the company, the coolant's blend of chlorinated EP ingredients ensures that it provides enhanced lubricity, corrosion resistance and cleanability. The bio-resistant coolant provides an environment that is not conducive to microbial growth without the use of biocides, dicyclohexylamine or other secondary amines.
  • alloys
    alloys
  • aluminum alloys
    aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wrought compositions and casting compositions. Some compositions may contain up to 10 alloying elements, but only one or two are the main alloying elements, such as copper, manganese, silicon, magnesium, zinc or tin.
  • coolant
  • corrosion resistance
  • extreme pressure additives ( EP)
    Cutting-fluid additives (chlorine, sulfur or phosphorus compounds) that chemically react with the workpiece material to minimize chipwelding. Good for high-speed machining. See cutting fluid.
  • lubricity
    lubricity
    Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
  • metalworking
    metalworking
  • stainless steels
    stainless steels
