Type 1 Wheels
Type 1 Wheels
A line of cotton fiber abrasive wheels for removing rust, corrosion, and thread-lock from pipe threads during oil field inspections and process maintenance, as well as deburring manufactured pipe and tubing, is available from Rex-Cut Abrasives.
Type 1 Wheels for pipe thread maintenance feature multiple layers of non-woven cotton fabric and aluminum oxide abrasives pressed and bonded together with a soft bond and are ideally suited for removing rust and corrosion from pipe threads. For thread-lock removal without changing the thread geometry, Smooth Touch wheels with a medium bond are recommended and last up to five times longer than unitized wheels, claims the firm.
Developed for use on stainless steel, Inconel, and other highly-alloyed pipe and tubing, Rex-Cut Type 1 and Wheels for pipe thread maintenance are available 1⁄16", 1⁄8" and ¼" thick and 2", 3" and 4" sizes. For manual or robotic deburring and finishing of machined and cast parts, different grit types, grain sizes, and bonds are offered.
