Dovetail grooving inserts, Static O-Ring Grooves
Manufactured by Kaiser Tool Co., the THINBIT GROOVE 'N TURN line includes Dovetail grooving inserts and Static O-Ring Grooves. The inserts are for machining O-ring dovetail grooves with 66° undercut angles. According to the company, the insert design is optimized for strength by using a left/OD and right/ID insert pair to generate the groove form. Static O-Ring Grooves are available in OD and face grooving styles.
