Hi-Powr Magnetic Sheet Fanners
Eriez Hi-Powr Magnetic Sheet Fanners feature a strong magnetic circuit that makes semi-sticky, oily, bent and heavy steel separate with incredible ease.
Eriez Hi-Powr Magnetic Sheet Fanners feature a strong magnetic circuit that makes semi-sticky, oily, bent and heavy steel separate with incredible ease. They bring unrivaled efficiency to slow, difficult sheet feeding for presses, brakes and shears.
With Eriez Sheet Fanners, prying "doubles" and marring of the polished and painted sheets are things of the past. Intelligently designed with hand cutouts, the units can quickly and easily be moved from one point to another. Plus, their sturdy base enables fast mounting to any flat surface.
The rugged magnetic circuit is completely enclosed, tamper-proof and will withstand severe usage. All Eriez Sheet Fanners are built with stainless steel U-shaped frames with stainless antifriction strips and back covers.
Eriez Sheet Fanners are available in three strengths and four functional heights to match customers' exact requirements. They are suitable for applications up to 1⁄8" (3mm) thick steel sheets stacked up to 14" (355mm) high.
