![Klübersynth GE 14-151 Grease for Highly Loaded Small Gears Klübersynth GE 14-151 Grease](/sites/default/files/styles/product_image/public/product_images/KlubersynthGE-photo.jpg?itok=RuB4QENE)
Klϋber Lubrication introduces Klübersynth GE 14-151, a special grease for highly loaded small gears like those found in power tools. This product consists of a finely balanced combination of ester and synthetic hydrocarbon base oils with an aluminum complex soap thickener. Klübersynth GE 14-151 has a wide service temperature range, good wear protection properties and a high scuffing load capacity. It also offers excellent protection against tribocorrosion.
Klübersynth GE 14-151 can be used to lubricate toothed wheels, bearings, joints and slideways. The optimized oil release behavior enables use in applications that are not sealed oil tight. With a high scuffing load capacity and good backflow behavior, the grease allows lubrication of gears with a high sliding ratio. Depending on temperature, load and sliding speed, Klübersynth GE 14-151 can even be used on steel/steel, steel/aluminum and aluminum/aluminum components. When used for lubricating trapezoidal and ball-and-screw spindles, it offers excellent wear protection and smooth running.
Klübersynth GE 14-151 can be used in gears operating at peripheral speeds of approximately 10 m/s with a quasi-complete fill of the gear housing. It can maintain speeds of 20 m/s over short-term or intermittent operation. Tooth flank lubrication allows a speed of 3 m/s.
