MLS Series Wheeled Load Skates
Cost-Effective Option for Moving Heavy Equipment in Restricted Spaces
Industrial movers have a new option for moving machines and equipment. The Enerpac MLS-Series wheeled load skates are a safe and stable option for machinery relocation and installation. When it comes to safety, the MLS-Series features a stable, wide footprint with padded tops for a non-slip surface.
Limited space and minimal headroom are typical challenges when moving equipment. The MLS-Series is compact. It’s low-height design is ideal for minimal lift heights and to accommodate limited clearance above loads. It’s also versatile. The MLSS models provides good directional movement. Meanwhile the MLSR models feature 360-degree movement ideal for tight spaces.
The MLS-Series is also easy to use. It features low rolling and rotational resistance. Additionally, its simple set up means even relatively new rigging operators can operate the equipment.
Enerpac MLS-Series Load Skates Features:
  • Low profile for minimized installation height
  • Rugged and reliable bearings for low rolling resistance and durability
  • High-quality wheels (nylon MLSR, polyurethane/optional nylon MLSF/MLSD) for stability and damage prevention to finished floors
  • Available in a wide range of load capacities from 3 to 35 tons
  • Set load capacities available from 6 to 70 tons
  • Easy-to-rotate turntable on MLSF models for enhanced maneuverability
  • MLSR models include 360-degree directional movement for load positioning flexibility in confined spaces
  • Configurable with towable or manual connecting bars and handles, depending upon model
  • Optional nylon wheel kit for better wear resistance and increased load capacity
  • clearance
    clearance
  • wear resistance
    wear resistance
