Polymer System EP31
Polymer System EP31
For superb adherence to a wide variety of substrates including many metals, plastics, rubbers, ceramics and glass, Polymer System EP31 was developed by Master Bond Inc.
July 1, 2010
For superb adherence to a wide variety of substrates including many metals, plastics, rubbers, ceramics and glass, Polymer System EP31 was developed by Master Bond Inc. This two-part system features extraordinary adhesion with a lap shear strength exceeding 4,600 psi, a peel strength surpassing 40 pli, a tensile modulus of more than 410,000 psi and a flexural strength of over 13,000 psi. With an excellent resistance to many chemicals including water, oil and fuels, it is also an outstanding electrical insulator. EP31 has a versatile cure schedule and can cure at room temperature or more quickly at elevated temperatures. Other notable characteristics include a Shore D Hardness of greater than 75 and low shrinkage upon cure. It is easily processed with a convenient 3:1 mix ratio by weight and has a service temperature range of -60°F to 250°F. Available in both black and optically clear, EP31 is sold in half pints, pints, quarts, 1 gallon and 5 gallon containers. It is also available in a convenient non-drip version called EP31ND.
  • shear strength
    Stress required to produce fracture in the plane of cross section, the conditions of loading being such that the directions of force and of resistance are parallel and opposite alt…
