SHUR-BRITE Mounted Seamless Satin Finishing Wheels
Made without a scrim reinforcement, the SHUR-BRITE® Satin Finishing materials are lighter, more pliable, and conformable than other non-woven materials. Suitable for wet or dry applications, they are resistant to loading, and produce consistent performance throughout their extended life. Available with ¼" shank, 2-inch width, and 3- or 4-inch diameter, in medium, fine, and very fine grades. n
Superior Abrasives, LLC's SHUR-BRITE Mounted Seamless Satin Finishing Wheels have a unique seamless structure for de-polishing and matte finishing without harsh and visible transition lines which are often seen with traditional flap brushes.
Aluminum oxide grains provide long life and withstands high pressure in general purpose applications. Silicon carbide grains provide a fast cut and uniform finish, with a sharper, finer cut. Slower speeds provide better finishing results, between 3,000 to 4,000 RPM. Ideal for use on ferrous, non-ferrous and stainless materials on applications like blemish removal, flash removal from non-metallic composites, gear and thread cleaning & micro-deburring, stainless steel cleaning and grain finishing, and reducing or blending fine scratch patterns, all without undesired transition lines.
SHUR-BRITE® Satin Finishing Wheels also available in Flap and Duplex Brushes for angle grinders, utilizing an integrated, toolless threaded hub for fast changeover.
