Venturi Pump Kit
Venturi Pump Kit
Removing coolant that naturally accumulates in a chip hopper enables longer production runs, eliminates messy cleanouts and reduces coolant costs. A new venturi pump kit from LNS makes the process of removing coolant from chip hoppers virtually effortless.
July 12, 2017
The easy-to-install kit continuously draws coolant from the chip hopper through a filtering screen and returns it to the machine tool tank, thus eliminating cutting fluid waste and allowing the hopper to hold more chips. As a result, there are fewer interruption of production runs, and the messy job of cleaning out coolant-filled chip hoppers is eliminated.
  • cutting fluid
    Liquid used to improve workpiece machinability, enhance tool life, flush out chips and machining debris, and cool the workpiece and tool. Three basic types are: straight oils; solu…
