CTE
Resources
Curated machining knowledge, tools, and pathways — organized by purpose.
MFGAxis — Buyer’s Guide
Company listings, capabilities, certifications, and specialties — organized for buyers and engineers.
Machining References
Curated technical references for machinists and engineers.
Machining Calculators
Feeds, speeds, formulas, and shop calculators.
Wire
Search-driven resource hub for wire.
Hypertherm
Search-driven resource hub for hypertherm.
Roll
Search-driven resource hub for roll.
James
Search-driven resource hub for james.
Molybdenum
Search-driven resource hub for molybdenum.
Ai
Search-driven resource hub for ai.
Browse 51 more topics
Vericut
Search-driven resource hub for vericut.
Siemens
Search-driven resource hub for siemens.
Fanuc
Search-driven resource hub for fanuc.
Turnkey
Search-driven resource hub for turnkey.
Super
Search-driven resource hub for super.
Robotmaster
Search-driven resource hub for robotmaster.
Pronest
Search-driven resource hub for pronest.
Online
Search-driven resource hub for online.
Tap
Search-driven resource hub for tap.
Optical
Search-driven resource hub for optical.
Machinist
Search-driven resource hub for machinist.
Broaching
Search-driven resource hub for broaching.
Fatigue
Search-driven resource hub for fatigue.
Search-driven resource hub for photo.
Makino
Search-driven resource hub for makino.
Erp
Search-driven resource hub for erp.
Countersink
Search-driven resource hub for countersink.
Flame
Search-driven resource hub for flame.
Fives
Search-driven resource hub for fives.
Centerless
Search-driven resource hub for centerless.
Garant
Search-driven resource hub for garant.
Filtration
Search-driven resource hub for filtration.
Go
Search-driven resource hub for go.
Dual
Search-driven resource hub for dual.
Okuma
Search-driven resource hub for okuma.
Acme
Search-driven resource hub for acme.
Tapping
Search-driven resource hub for tapping.
Raw
Search-driven resource hub for raw.
Co2
Search-driven resource hub for co2.
Pre
Search-driven resource hub for pre.
Total
Search-driven resource hub for total.
Moving
Search-driven resource hub for moving.
Abb
Search-driven resource hub for abb.
Formula
Search-driven resource hub for formula.
Pick
Search-driven resource hub for pick.
Automating
Search-driven resource hub for automating.
Sic
Search-driven resource hub for sic.
Pipe
Search-driven resource hub for pipe.
Coordinate
Search-driven resource hub for coordinate.
Tramp
Search-driven resource hub for tramp.
Thermal
Search-driven resource hub for thermal.
Cmm
Search-driven resource hub for cmm.
Ceramic
Search-driven resource hub for ceramic.
Case Hardening
Search-driven resource hub for case hardening.
Insert Geometry
Insert identification, lead angle, indexable insert geometry, and selection references.
Boring
Boring heads, U-axis systems, contour boring, and setup references.
Cutting Forces
Cutting-force formulas, machining power, chip load, and speed/feed references.
Workholding
Workholding strategy, zero-point clamping, fixturing, and setup efficiency.
Threading
Threading calculators, tapping guidance, thread milling, and related tooling.
Authors
Browse CTE contributors and subject-matter experts.
Glossary
Definitions of machining and manufacturing terms.
Latest articles, videos, products, and news from across CTE that fit the same machining-learning path.
Browse results
Custom solutions for machining center tooling
Product October 26, 2026
Platinum Tooling now offers custom machining center tooling solutions, designed around the unique requirements of each application. From modifications to existing tooling to completely new designs, Platinum Tooling says its team combines precision, expertise and application-focused engineering to solve challenging tooling needs.
Angle heads and REV broaching | Platinum Tooling at IMTS 2026
Video October 23, 2026 Timothy Spaeth
IMTS 2026 coverage Platinum Tooling is a CTE advertiser. Preben Hansen explains standard and custom angle heads for machining-center access, then introduces REV automatic broaching tools for keyways and internal or external splines. Original booth close-ups show the angle-head designs and REV tools separately.
Swiss tooling and live tools | Platinum Tooling at IMTS 2026
IMTS 2026 coverage Platinum Tooling is a CTE advertiser. Preben Hansen demonstrates a Swiss speed increaser that multiplies speed four times to 48,000 RPM and introduces Heimatec live tools for turning centers. Close-ups from the original Platinum Tooling shoot show the same products at IMTS 2026.
1 2 3 … 1,442
